cam or heads and cam?
Old Oct 2, 2002 | 03:35 PM
rnr27band1's Avatar
Default cam or heads and cam?
Ok I am thinking about getting a cam now and then getting stage 2 heads later. but do yall think I should just wait and get it all at the same time? I was thinking about getting a reverse split cam and I have no clue what kind of heads. I dont plan on doing any kinda stroker motor or bored motor but I would possibly put a 150 to 200 wet shot on the car.
Old Oct 2, 2002 | 07:41 PM
Zshark's Avatar
Default Re: cam or heads and cam?
all that i know, and that is not much, is that the stock heads prolly cant take the same kind of wicked lift and what not that a set of stage II heads can. you may just want to go a milder cam now and swap that later along with the heads. just hold up some bank playa-we all know your from the hood!
<small>[ October 02, 2002, 10:02 PM: Message edited by: Zshark ]</small>
Old Oct 2, 2002 | 10:21 PM
rnr27band1's Avatar
TTT
i am thinking just get the cam, and some drag raidals and a gear, then get the heads later
Old Oct 3, 2002 | 06:37 AM
99hawk297's Avatar
Alot of people do the heads later. Just make sure you upgrade your springs and push rods when you do the cam. You will still get good gains.
Old Oct 3, 2002 | 06:47 AM
Stu's Avatar
Stu
Cam only car here.....Went from 12.7's@108 to whats in my sig spinning my rear off. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Very happy with gains.
Stu
Old Oct 3, 2002 | 02:32 PM
Dad's Toy's Avatar
See "Dyno results for GTP 2 heads/ reverse split cam!!" posted September 24th
Car is a blast to drive, I had fun when it was stock but nothing compared to now.
if you have the $$ go cam and heads. (there where other mods also done at the same time)
can't go wrong what ever you do, good luck
