My ARE flow sheet for 5.3 heads
lift int ex.
200 133 107
300 192 142
350 218 156
400 237 169
450 255 180
500 270 190
550 284 194
600 295 203
just though I'd share (no bashing here, just info). Some GTP's I've seen have had similar figures, while some old MMS heads were up around 75%. Stock is close to 82%.
still, what flow numbers wont show...is velocity.
Ryan
<small>[ October 03, 2002, 11:30 PM: Message edited by: Ryan ]</small>
One guy had his MTI heads flowed at a different place and they went from the ~307cfm MTI proposed to just over 290cfm that he saw on the bench.
Was MTI lying? NO but benchs read different values. So much for these expensive flowbenchs them reading exactly the same between machines. LOL!
You will see this with all the major sponsors. It isnt the porter but differences between the flow benches. Just like you see variance between dyno numbers at different locations. Two heads flowed on the same bench on the same day will give a better representation.
Cheers,
Chris
<small>[ October 04, 2002, 07:24 AM: Message edited by: Chris ARE 360 ]</small>
so if you post your numbers it correlates something or validates ARE...but if i say they are 20cfm low...ITS A DIFFERENT FLOW BENCH!!! BS!
you flowed your **** on a different bench as well, so edit your post or STFU.
His stuff was flowed on AREs bench wasnt it?
That is where mine was flowed as well <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I dont understand (unless his was flowed on a different bench)
Chris
anyway. the percentages are straight from the numbers he posted. less than 70% tells me to crutch the exhaust side of the motor. just an observation from some recent ARE heads.
again, numbers dont mean ****. velocity is key.
Joe.
Do you think it's a good idea that all the flow numbers should be e-mail in from the participating shops to someone like you and posted when all the shops have checked in? and would you coordinate this? I feel that if there is a data base made up, it would be a great asset to see how one shops heads flow directly compared to another, then we would have a true Benchmark.
Joe.
