Compression?
Old Mar 19, 2007 | 06:24 PM
craze4speed's Avatar
Default Compression?
i am about to pull my engine to swap heads and cam and i am considering putting a new set of rings in also, i was wandering if anybody ever checked there compression on a stock ls1 and what kind of numbers did you see, i checked and mine are around 150psi, but it seemed kinda low, but i dont have anything to compare to, any help appreciated.
Old Mar 19, 2007 | 06:54 PM
ArrestMeRed99Z28's Avatar
try running a search in the sticky in the newby tech section, it has tons of great information about the stock specifications of the LS1.
Old Mar 19, 2007 | 08:21 PM
brad8266's Avatar
if they are all close to each other then you are good to go.
