whats this stuck to my drain plug? (pic)
You have me a bit confused here.I believe the only lubrication the valve train receives is from the small holes in the push-rods.Maybe you can explain to me,if you know something that I dont.
If you pull the valve covers off and the retainers are good, I'd say seat. I wouldn't keep driving it like some suggest. Take care of a possible problem when it comes to the inside of the motor. Hope it helps.
I personally think someone accidently dropped whatever that was in an intake port when the intake was off for the cam, or some other way when he had the cam installed. I just think something out of the valvetrain that size would be very noticable when the car was running. How many oil changes ago was the cam put in?
I wouldn't say there is no way, I've seen valvetrains come apart. I've seen needle bearings, spring pieces all make it to the oil pan. I think with the pressure of a rocker the spring could still be retained by part of the retainer if the center section is intact. It won't last long, but it could still be retained. A retainer could have had a fracture from the factory and he never seen it.
The problem is, you just don't know until you explore. You know something is wrong, and I just don't see why some on here say drive it. You need to find the damaged area and fix it. The valve covers are an easy start, and work down from there. Simple fact is, it resembles a piece of valvetrain.
Just my 2 cents.
I found the EXACT same **** on my drain plug the last time i changed my oil!!!
I have yet to figure out what it is. I thought it was a valve seat too at first but i have Patriot Gold Duals and when i looked at one of those seats they didnt look the same (to me atleast). So i really dont know what the hell to think! I REALLY dont want to redo the valve springs a THIRD time! that **** gets old! But i'll keep checking in on this thread and see what comes of it. Brent
not pretty. I think whatever that was got there some other way.
You have people here saying they have seen things like this happen, but yet tell this guy it can't happen. Great advice here.
If you were joking, ignore.
Mine has a catch can with a breather, no more oil.
You honestly thought that I could have been serious..... with the
and everything?
you need to get out more.
