loud tapping goes with the rpms PLEASE HELP
http://www.youtube.com/watch?v=z3sdg_0ksjs
Pretty noticable, but just because you car doesn't sound like this doesn't mean its not a spun bearing...although if it is the other bearings wont be getting lubed like they should and they may fail too...in which case you would definatly see low oil PSI
Taking it to 6600 with the modifications that you have should not have damaged anything as long as it was not there for an extended period of time. Could it be possible that it has been there and you just now have noticed it after revving the motor like that?
