loud tapping goes with the rpms PLEASE HELP
Old Mar 21, 2007 | 05:46 PM
fstls2camaro's Avatar
Default loud tapping goes with the rpms PLEASE HELP
hey whats up i just got my car dyno tuned and when i was driving it home i revved the motor to about 6600 rpm but when i got home it was making a loud tapping noise and it goes with the rpms what do you think it could be my oil pressure is still good.also how do you check if i collapsed a lifter.
Old Mar 21, 2007 | 06:09 PM
ArcticZ28's Avatar
Could be a lifter, bent pushrod, a rocker bolt could have backed out.... Time to open up the valve covers and check it all out. If everything looks kosher, then you'd have to pull the heads to check the lifters.
Old Mar 21, 2007 | 08:32 PM
jay_99z's Avatar
Did you check your oil level? If it's low......it could be a spun rod bearing.
Old Mar 21, 2007 | 08:33 PM
ArcticZ28's Avatar
If his oil pressure is good, it won't be a spun bearing.
Old Mar 21, 2007 | 08:43 PM
Billf6531's Avatar
Wrong ... oil pressure doesn't=oil capacity/volume.
Old Mar 21, 2007 | 09:18 PM
ArcticZ28's Avatar
What are you talking about?
01redws6ta's Avatar
Does the noise sound like valvetrain (upper/half speed) or bottom end? You can place a stethoscope or long screwdriver on the valve cover and listen for the area that is loudest for valvetrain. It may be counting a few missfires on suspect cylinder too (may not be enough to set code). You could have it scanned.
Old Mar 21, 2007 | 09:36 PM
Billf6531's Avatar
Drain two quarts of oil. Did your oil pressure change?
Old Mar 21, 2007 | 10:22 PM
ArcticZ28's Avatar
Edit: I see that you weren't talking to me, but the guy that posted right before me. I was really confused for a second there. I thought your comment had something to do with mine due to the fact you posted right after me.
Old Mar 21, 2007 | 10:55 PM
02NBMWS6's Avatar
it had everything to do with yours, he's saying it could still be a spun bearing with good oil pressure.
Originally Posted by fstls2camaro
PLEASE HELP
you guys werent gonna beat me anyways...
jk, good luck
Old Mar 21, 2007 | 11:04 PM
ArcticZ28's Avatar
Actually, if you look at the post right above mine, that's what he's referring to. I have no idea how he could be referring to my post(s). If you have any clue as to how the oil propagates through the engine you would know that a spun bearing opens up a lot of clearance between it and the crank or cam, whichever one it is. More clearance equals less pressure in the system. This is a tell-tale sign of a spun bearing.
Old Mar 21, 2007 | 11:09 PM
02NBMWS6's Avatar
dude, he quoted you. twice. maybe you disagree about the oil pressure thing. but i am pretty sure he is saying that you can have low oil (which could cause a spun bearing) and still have good pressure
Old Mar 21, 2007 | 11:21 PM
ArcticZ28's Avatar
I don't think you get what I'm saying here... I'm giving him the benefit of the doubt, albeit a far stretch from reality. Nonetheless, low oil does not mean low pressure. I'm not sure who said it did or why he thinks that's what was inferred. I don't think anyone knowledgeable would argue that a spun bearing doesn't give a noticeable loss in pressure, most of the time an unquestionably severe drop. Maybe what's up for debate is what "good" and "low" oil pressure is... I can only speculate until he responds.
Old Mar 22, 2007 | 01:45 AM
jay_99z's Avatar
Damn all this for me?
A friend of mine spun a bearing and there was no change in oil pressure (that we saw). Had a tick that we were sure was valvetrain noise. Finally tore down the engine and saw what the cause was.....two bearings that looked pretty bad and another that was worn. This "tick" started after a WOT run down 1 quart of oil.
I'm not going to argue the point. There are too many experts on here for that. All I'm saying is what I saw and heard on his engine.
Old Mar 22, 2007 | 06:20 AM
Dustin 98TA's Avatar
Low oil level doesnt affect pressure unless it gets low enough to cavitate the pump. A spun rod bearing may not show much drop in oil pressure, ive seen it time and time again.
Old Mar 23, 2007 | 12:54 AM
would the car run like crap after a spun rod bearing and would there be metal shavings in the oil or the filter.
Old Mar 23, 2007 | 11:34 AM
anyone
Old Mar 23, 2007 | 11:36 AM
ArcticZ28's Avatar
There is no definitive answer for that. You could have those things or not. It's kind of a crap shoot at times.
Old Mar 23, 2007 | 11:54 AM
UCNTZME's Avatar
If there is a spun bearing, more than likely there will be copper color shaving in the oil filter cut it in half and look at the element in the filter. I have definately seen on more than one occasion a spun bearing not affecting the oil pressure.
Old Mar 23, 2007 | 12:03 PM
ncd1966's Avatar
might be rocker arms I know I have one making some noise but its not all the time.
I will be changing all of them in a week
