Doing head work....which valve springs?
Old Oct 13, 2002 | 09:16 PM
2001CamaroGuy's Avatar
Default Doing head work....which valve springs?
Ok....I am talking to a guy who has a set of 99 5.7 heads w/ comp 941s and Lunati Ti Retainers. He will sell me just the heads for $200 or the heads/springs/retainers for $325. The springs/retainers have about 30k miles on them.
I want to use the Thunder Racing 224/224 .561/.561 112 LSA cam.
When I get the heads, I will be having them ported and polished (may have them milled 0.030 for increased compression).
Should I get the springs or just the heads and get new springs/retainers?
Since I am having head work done anyways, should I just get duel valve springs installed? Any idea what the would cost and which springs should I use?
<small>[ October 13, 2002, 09:20 PM: Message edited by: 2001CamaroGuy ]</small>
Old Oct 13, 2002 | 11:18 PM
99 Black Bird T/A's Avatar
Default Re: Doing head work....which valve springs?
I think duals springs are best.
TR-224 has very aggressive lobes.
Rev has a new kit that doesn't require maching the heads to accept dual's that will allow dual springs to be installed.
Old Oct 14, 2002 | 01:38 AM
Has anyone had exsperience with the REV springs? They sound really nice.
Old Oct 14, 2002 | 06:37 AM
cantdrv65's Avatar
Buy some 918 springs, 30,000 miles is about time to change those springs. Wore out.
Old Oct 14, 2002 | 07:32 AM
LS1derfull's Avatar
Machining heads for dual springs will leave very thin area when heads are ported. If you need dual springs fine but i would avoid this by running 918 springs.I am interested in Rev spring info.
