How do the GM CNC LS6 heads compare to the average Stage 2 LS1 head?
boy see how those lazy abbrevatons mess things up hehehe i am running no power adder i want raw power
george
george
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Trevor D:
<strong>Are LS1 valves the same length as the LS6 valves? If so, you could just transfer them over.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I read an article that stated the sodium filled 2002 LS6 valves are longer than the LS1 valves since the 2002 LS6s cam has a smaller base circle than the LS1.
19.0 mm VS the LS1s 19.7 mm
That .7 mm equals .028"
Both engines use the same 7.40" pushrod
<small>[ October 16, 2002, 11:13 PM: Message edited by: Kimchee and Rice ]</small>
I guess I spoke kinda too soon. I do know someone who is running these heads. I forgot what cam he said he was running. I dont know what kinda power he is putting down, but I can tell you that NA he is running high 10's @124 MPH, in a car that weighs around 3400?? I witnessed the runs myself. I dont think he has the car intended as a street car as much as a strip car.
I wonder why they are milling the heads, and why you cant get just a plain one with the assembled valves? That sucks.
SDPC sells GM ported LS6 heads for $980 per head fully assempbled!
Unfortunatly, they are milled .055 and the chambers are reduced so I assume the compression would be very high for street use....
SDPC sells GM PORTED LS6 heads for $980 per head fully assempbled!
The heads are brand spanking factory NEW not used like other ported heads and the transaction does not require the buyer to return a core or pay a core charge.
Unbeatable you say? Only is someone can assure me this combo would work on a street machine burning pump gas....
