Vengence Vindicator .022" Piston To Valve WTF?
That is why I always preach to check PTV and degree cams that big and not just take a vendors "word" for it.
https://ls1tech.com/forums/showthrea...ht=MS4+110+LSA
Nice irrefutable proof in this thread (props to the poster)
I am with you on that one. After a few discussion I realized there are some people who know nothing about engines, and it is hard to try and explain reality to them.
This post is definitely interesting. I know you normally do not see many people on here who actually check and post the PtoV numbers in such detail.
I measured my PTVC and posted a lengthly thread about it a few months ago.
No reason to bust him in the chops... this is good info we can all use. There was nothing ugly or uncalled for in his post. I see no reason to go into vendor protection mode over it...
Props to the poster and PREDATOR-Z
I did a back-to-back PtoV check about 4 years ago (228R cam) using clay with stock hydraulic lifters and then using a dial indicator (my preferred method). I did the clay test about 4 times to get an average measurement, which was a PITA to do anyway to get anywhere near precise. Then I used a dial indicator/adj. pushrod method and was about .020" difference each time, the clay showed more clearance for me being the lifters absorbed some of the lift...even with test springs. With my experience using clay, I could see the end results being skewed depending on the end user and the procedure used.
The dial indicator method has been the most repeatable and accurate method I've ever used. Although if I have the heads off, I also use solid lifters just to be sure. Setting the preload/lash to zero makes a huge difference in the measurements, I believe thats what a lot of people miss as it seems no one knows what lash/preload means.
As for the Vindicator, we have checked P/V in house on an LS6 and an 02 LS1. Both were in the low .050s on the engines we used. I am sorry you are having clearance issues. As we all know every engine/camshaft is different and has different tolerances.
We will be more than happy to send you a piston notching tool or take a full refund on the camshaft, whichever you prefer.
Again, thank you for posting your results. This should remind others to ALWAYS check P/V no matter what size the camshaft is.
I think all cam designers/vendors should be stating PTVC on their cams on stock motors/heads, that would help in being more informative for the customer when selecting a cam. Im not pointing the finger at vengeance though since all other cam vendors dont do it either, but this thread has shined light to the subject.
