Bottom of Fast 90 intake cracked??
Old Mar 24, 2007 | 06:09 PM
SPRAYED 01's Avatar
Fixed mine up today. Im a huge idiot because i found the bolts in my old garage. I couldnt see any cracked on the bottom. But i took a boroscope to the inside and there were 3 good size cracks. Not sure if that was causing a vacum leak. The car seems to drive pretty much the same as before. Little less idle hang. Also did the ls6 pcv valley while i had it off. Alls good thanks for all the help.
Old Mar 24, 2007 | 06:40 PM
pdd's Avatar
pdd
congrats on getting her running again
Old Mar 25, 2007 | 06:11 AM
vettenuts's Avatar
Just curious, which boroscope do you have, is it the batter powered one I see advertised? I have one I get from work, but I don't like taking it as it is worth a ton of money and would prefer to have one of my own.
Old Mar 26, 2007 | 05:48 PM
Rosco's Avatar
Originally Posted by HEMIETR
Its only a $400 mistake.
As I found out when I slightly over torqued the intake bolts with the knock sensor wires in the way!
Big ol crack between the last two ports! had to go back to stock for the time being till my new bottom part arrives!
Is there anyway that they can be fixed?
Old Mar 26, 2007 | 06:28 PM
brad8266's Avatar
JB Wels FTW!!!
I would replace the lower intake though if i broke mine.
Old Mar 26, 2007 | 07:47 PM
Rosco's Avatar
Originally Posted by brad8266
JB Wels FTW!!!
Well ive already ordered one, just have no idea how long its going to take to get here so was thinking of trying to fix it for use in the mean time.
Old Mar 26, 2007 | 10:30 PM
SPRAYED 01's Avatar
Im not sure on the boroscope i used. We just got it in at my shop. I know its about 4k and has its own 8inch screen tv monitor. I see nothing wrong with fixing the cracks. It worked out really well. Im glad i didnt spend 400 on a new bottom.
Old Mar 26, 2007 | 11:34 PM
exSSer's Avatar
Here's a picture of the bottom of a FAST manifold, after a real man tried to install it without instructions.
Old Mar 27, 2007 | 08:23 AM
SPRAYED 01's Avatar
Thats alot worse than mine.
Old Mar 27, 2007 | 08:29 AM
brad8266's Avatar
Ouch.
Old Mar 27, 2007 | 08:57 AM
MightyBobo's Avatar
true i just tighten by hand,but my hand is like a torque wrench now, lol. You dotn need to torque them perfect buy if you over due them you can strip out the blocks threads. That goes for any bolt hole in the aluminum block.
Good point, Ive just become a stickler for getting the proper torque specs.
Now that I think of it though, I only had the FAST instructions handy and there were no specific torque specs for those so I just tightened them in a star pattern.
Old Mar 27, 2007 | 09:26 AM
  #32
LS1Formulation's Avatar
Yes, they are blind, I believe. They don't require sealer so that leads me to believe they don't contact oil at all.
Old Mar 27, 2007 | 10:02 AM
  #33
Rosco's Avatar
Thats how bad mine is, going to try to fix it! its not like I can really make it any worse than it already is!
Old Mar 29, 2007 | 07:04 PM
  #34
myws61's Avatar
Well Mine im sure is cracked as well, now that I read this, so Ill be sure to post some pictures and let you know what it looks like after a real man has done the install without reading instructions.
Old May 4, 2007 | 09:38 PM
  #35
cvman's Avatar
Not wanting to seem ignorant, but what are those wires for coming out of the center of the valley cover? My 5.3 doesn't have those.
Old Feb 16, 2008 | 07:57 PM
  #36
55LS1's Avatar
Edit: Went out to the garage & pulled the intake off, sure enough you can see the indentions of the bolt heads, although I don't see cracks. Hopefully I lucked out! I will be picking up the button head bolts first thing tomorrow!
Sorry to bring up this thread from the dead, but I bought my 90 in 2004 and it didn't come with any buttonhead hardware. I haven't pulled the intake off yet to check it, but I just tightened the intake by hand, hoping mine isn't cracked!!! Anyone have a pic of one with cracks & where I should look? Thanks!!!
Old Feb 17, 2008 | 04:21 PM
  #37
myws61's Avatar
Lucky! Mine was cracked in a few places but I sealed them up and it works fine now, no leaks!
