oil pressure question
Old Oct 15, 2002 | 08:14 PM
EVIL's Avatar
Default oil pressure question
if in atap, you are seeing zero volts from the pcm on the oil pressure sensor, could there be a problem with the sensor? when i pulled my motor out, we broke the wire for the sensor that i think is the oil pressure. we soldered it back and heat shrinked it up, but i am thinking that my oil pressure is reading way too low for having a new motor with a katech oil pump.
