To build my engine a little bit.
BadAssY2KTA - I have the forged pistons you need on the shelf. They are a stock replacement piston for the LS1 and they have -2cc valve notches in them for oversized valves. There cost is $570.00 a set with wrist pins. If those are not what you are looking for give me a call and we can see what you need.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Thanks,
Chris Gelineau
Diamond Pistons
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DIAMOND:
<strong>BadAssY2KTA - I have the forged pistons you need on the shelf. They are a stock replacement piston for the LS1 and they have -2cc valve notches in them for oversized valves. There cost is $570.00 a set with wrist pins. If those are not what you are looking for give me a call and we can see what you need.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris, are these pistons forged? How strong are they compared to the Hypercrap stockers? I'm building a stock cubed motor for a back-up if my stock 80K motor decides to take a dump on me ...I would like some info on your pistons...N20 will be used on the motor FYI.
Thanks,
Chris Gelineau
Diamond Pistons
I was wondering how much it would cost, to build my engine up a little bit. Like new pistons(fly cut), rings, ARP head studs, new rod bolts, and anything else that is necessary to build a strong/killer 346 minus the heads and cam, I already know where I want to go with them. Also how hard is it to install these parts in your garage, I have done everything else so far and it wasnt that bad.
JoSey - Our pistons are all forged, that is all we make. A forged piston is much stronger than the cast pistons or the hyperutecnics. I might have misspelled that. Our off the shelf pistons will handle a 150 shot all day long, if you are going to spray it with more than that I would recommend that we make you a custom that you could spray the hell out of. Give me a call and we can work on a pistons for you, I can also send you out a catalog. Just give me a call.
Thanks,
Chris Gelineau
Diamond Pistons
Thanks,
Chris Gelineau
Diamond Pistons
I just finished with mine here are some prices for u.
Ross Forged Flat tops with Total seal rings $692.00 from Futral Motorsports
Rod bolts from Katech $122.00
ARP head studs from katech $205.00
Federal Mogul main bearings $78 from Napa
Clevite rod bearings $56 from Napa
Polish your stock crank and rods
this is good for 600-800hp depending on how high u plan on taching it, no more than 67-6800rpms
