built 6.0. opinons plz.
Old Oct 21, 2002 | 06:16 AM
BYBYC5's Avatar
*Bad Trader*
Default built 6.0. opinons plz.
im thinking of a 6L with my tr230/224, 5.7 headsmilled .015 and a nice size n20. what do ya think the C/R would be on a 6.0 (dished pistons i beleive) with milled ..015 heads. i dont know the formula to apply here,
the 6.0 should go right in with no problem cept making one hole for my alt bracket(anyone know how or where to drill this hole).,, need all the help i can get.
Old Oct 21, 2002 | 08:20 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: built 6.0. opinons plz.
ttt
Old Oct 21, 2002 | 09:11 PM
steve's Avatar
i need more specifics to give you an accurate comp ratio.
i come up with around 10.8:1 if you use these figures...
65 cc head, 0 cc piston at 0 deck.
3.625 stroke on a 4.001 bore with a .054 gasket at 4.010....
if you want it a little more accurate, give me the details of the motor ect..
steve frank
Old Oct 21, 2002 | 09:55 PM
BYBYC5's Avatar
*Bad Trader*
as i under stand it the 6.0s have dished pistons, the stock C/R is 9.4 or 9.5 with stock 6.0 heads. i want to use 5.7 heads milled .015
Old Oct 25, 2002 | 11:11 PM
BYBYC5's Avatar
*Bad Trader*
TTT plz
Old Oct 26, 2002 | 05:21 AM
1dirtyZ's Avatar
for the bracket all you have to do is bolt the bottom part and position the bracket in where it will sit , then just use a center punch ( thick one so it centers itself in the alt. bracket hole) to mark the block then drill away. use the old block as a guide to how deep to drill.
