DESPERATE! new head cam package will not start
Originally Posted by dazman
i plugged the one that went to the back of the pass. valve cover. and im pretty sure there was only one little one on the back...
Coolant temp sensor plugged in and working? It defaults to -40 if unplugged or not making connection which would flood an engine pretty quick with that much fuel. Other things are the PCM grounds on the back of the drivers head, for a c5 there will be only one eyelet with 2 wires going into it.
You might just pull one plug and see if its dry or wet with fuel just to eliminate that. There isn't no weird theft deterrant problem going on? Some C5's I've worked on needed a theft deterrant relearn after having the battery disconnected a few days. Like 1 out of 50 will do that.
Originally Posted by brad8266
Well maybe the 97's only had one, mine has 2. You need to unplug that PCV hole and plug the PVC hose into it.
where should i stick that hose? just make a T that would run it into the other one that goes from the valvecover and the intake?
The PCV hose goes from the driver side valve cover and the pass valve cover into a Y and then on to the manifold up front by the throttle body.
now my car is a bitch with the column lock and stuff.. i have the column lock bypass and it is telling me to "pull key wait 10 sec" today. but it was doing that back before i even started working on car.
If he has a truck or any of the newer pass. side valve covers there is no provisions for the passenger side PCV hose. I end up having to eliminate the Y-portion and just putting a piece of 3/8" fuel line to only run PCV to the drivers side valve cover.
Can you get a pick of the back pass side of the valve cover and post it?
i dont have a camera, but it is the same as the one that came on it, minus a hose fitting on the back.
Originally Posted by Specialized
Im kinda tired, so I may have over-looked this, but has anyone suggested crank sensor? I had a similar issue with my car, didnt know until I scanned it. What do the P codes come up as?
P codes are ASR desired torque, bank 1 lean, and bank 2 lean.
and at this current time it is only the asr desired torque code... this is such a f-ed up problem. im completely stumped
im going to bed, i appreciate everyones help.
mike
For the hell of it, unplug that damn throttle control motor which the throttle cable gets split by. this will disable ASR completely (while unplugged).
**********NEW DEVELOPMENT*******
put in the old plugs back when motor was stock and car cranked right up!!!!!! but after initial start it will not find idle for ****. and now has problem starting and NOW IS THROWING THAT DAMN 0171 AND 0174 LEAN CODES!!!!!
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH but it is not throwing the p1571 asr code anymore.... what do yall think it is???
thanx!!!
mike
One thing I know is that if the gasket on the MAP sensor is torn: 1. you'll have a minor vacuum leak and 2. sometimes the MAP sensor will get a funky reading and make the car do some weird things.
Check and recheck everything. It would be hard to do, but I suppose an injector clip could get switched. Make sure all of your electrical connections are DRY. If there is any amount of moisture in there it will mess things up. trust me. Is every cylinder is getting spark? Those are my thoughts. Good luck.
oh hell.... my map sensor is being held on by electrical tape... because of the halltech intake i bought, we have to rig it.. i KNOW its prolly leaking there...
