DESPERATE! new head cam package will not start
what i did was take the sensor out of the rubber boot.... if you were to stick it in the hole on the intake it would be swallowed, so i wrapped it in electrical tape and if fits OK now... do you think that that would not be sealed up enough to make it create a large vaccum leak??
mike
I know without the bracket, i could wiggle/shake the sensor pretty easily.
and it ran without the bracket with no ill effects??
Im sure if you think it might be leaking, you can always try and sneak some kind of sealant back there while on yoru finger...
I know they mentioned before about the temp sensor... Is your car warming up at all?? I guess a better way to put it is, does it show it warming up on the guage?
you are a god damned dumb ***..... HAHHAHAHAHAHAHHAHHAA.... where is the damn 3rd gen, cause i see you found a mullet?!?!?!?
i just cranked it this morning and drove it up the road... bitch idle GREAT on startup, but will not find idle for **** after initial run, just like last night. we need to **** with that map sensor as well.
