Oil pump swap help needed
I need advice on dropping the oil pan 1/2" to swap a new oil pump I can only get the fron two bolts off any advice on getting to the other bolts does steering rack need to be pulled out?? Really don't want to do that.
Anyone have any tricks to swap oil pump?
2000 M6 Camaro
Installing In progress
MTI Stage IIE Heads
228/228 .600 114 lsa
7.4 Hardened Push Rods
LS7 Cadillac Racing Lifters
LS6 PCV Conversion
LS6 Ported Oil Pump
Also, don't forget that there are bolts running through the trans bell housing and into the back of the pan...
remember there are two larger bolts that go towards the front of the car, not up ... without taking those off it will not drop .... also remember to put something in there to stop the bolt from the pick-up tube from rolling in the oil pan .... i spent a good 2 hours trying to get the bolt out cuz it fell way to the bottom of the pan .... it was hell... i was worried i would have to drop tranny so that i could get the pan off
