Head Studs....Hex vs. 12-Point
Old Oct 22, 2002 | 11:40 AM
2001CamaroGuy's Avatar
Default Head Studs....Hex vs. 12-Point
I'm getting all the "toys" <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> together for my H/C swap and want to put head studs in. Which should I go with, the hex nut or 12-point nut? Is one stronger than the other? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Chris
Old Oct 23, 2002 | 12:28 AM
Phil99vette's Avatar
7 Second Club
Default Re: Head Studs....Hex vs. 12-Point
I went with 12 points torqued to 75lbs. I like the 12 points better because they are somewhat easier to torque due to design.
Phillip
Old Oct 23, 2002 | 08:23 AM
ibjamin's Avatar
Another question.
With head studs can you still remove and install the heads with the engine in the car? I assume the answer is yes but want to make sure.
George E.
Old Oct 23, 2002 | 08:30 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by phil97svt:
<strong>I went with 12 points torqued to 75lbs. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have the same setup, works great!
Old Oct 23, 2002 | 09:06 AM
Fulton 1's Avatar
In general 12-point fasteners are used for high-torque applications or where access is too limited for standard hex heads. I don't see any reason why you shouldn't use them...
<small>[ October 23, 2002, 09:12 AM: Message edited by: Fulton 1 ]</small>
