Porting heads - Intake airflow ??? w/ pics
BLUE ARROWS: There is a visible discoloration where air flows from the top of the intake down into the chamber.
GREEN ARROWS: Clean looking areas. No visible discoloration.
YELLOW AREAS: More discoloration, shows heavier buildup on the floor.
RED ARROWS: A visible buildup on the outer portion around the orifice to the gasket edge.
<img src="http://www.z71.net/intake1.jpg" alt=" - " />
90% of porting posts talk about keeping up airflow speed and not removing too much material. It looks like the RED arrows show a visible bottleneck that would hinder airflow. I didn't want to remove enough material to gasket match the ports. But should I round over the edges or flare them out a bit just to decrease the resistance entering the head? I am being cautious with this project and want it done correctly, but do want them to be worth my effort.
Any opinions?
* One other side note - The EGR discoloration isn't evenly spread across all ports in the head. Possible proof that since EGR doesn't get evenly distributed by the intake manifold, than neither would nitrous.
<small>[ October 22, 2002, 09:35 PM: Message edited by: BigTex ]</small>
Paul j.
IMO concentrate your porting efforts in the valve bowl and short turn radius. Minor mis matches at the manifold/head entrance don't mean as much to a street/strip engine as a high rpm race engine. Have a reputable machine shop do the valve job and let 'er rip!
Good luck,
Richard <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Richard
