Food for thought on some bigger Stroker Combos 480 inch LS1
LS1Tech Co-Founder
Also, if you run a DFI engine management system for the LS1, you do not need the crank position reluctor wheel. It uses a "FAST" system to monitor the cam position sensor instead of the crank position, and translates the info for the DFI control.
-Tony
-Tony
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>Also, if you run a DFI engine management system for the LS1, you do not need the crank position reluctor wheel. It uses a "FAST" system to monitor the cam position sensor instead of the crank position, and translates the info for the DFI control.
-Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I bet you just recently learned that? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
