View Poll Results: Which pistons would you go with?
Mahle -6cc
67
53.60%
Diamond -7cc
58
46.40%
Voters: 125. You may not vote on this poll
Diamond or Mahle?
Old Mar 28, 2007 | 07:18 AM
Gauge's Avatar
11Second Club
What is the material on the skirts and how is it beneficial? I noticed it when doing my rebuild but never really thought to ask.
Old Mar 28, 2007 | 09:28 AM
DONAIMIAN's Avatar
Originally Posted by camarokid94
lol i will be shootin 300 on mine this summer we shall see how they do.. i bet better than the 4 stock ones i blew up LOL
I VOTED MAHLE
The stock ones you blew up were MAHLE's too.
Old Mar 28, 2007 | 09:05 PM
DAVESS02's Avatar
If you had the tops of the 4032's ceramic coated, would that enable them to stand up to bigger shots of N2O?
Old Mar 29, 2007 | 10:26 AM
stevemilz's Avatar
I got these from Thunder Racing....
189-LS1314905F04
Mahle Motorsport Forged 347 cid LS1 Flat-Top Piston Set: 3.905" Bore, 3.622" Stroke, 6.125" Rod Length, .927" Wrist Pins, 1.314" CH, -4cc; Includes Piston Rings, Pins, and Spiro-Locks
$499.99
If you look around you can get 6.125" Scat I-Beams for under $280 (these are NON LS1 SPECIFIC) 2-ICR6125-7/16
Old Mar 29, 2007 | 10:37 AM
mdhmi's Avatar
I'm sure both are fine. My builder said he likes Mahle and JE. Mahle had a backlog at the time so we went with JE.
Old Mar 29, 2007 | 10:54 AM
1ImperialSS's Avatar
formerly silverbrick (changed 02/17/2013)
I too when with the Ebay package with Mahle pistons. My short block should be assembled pretty soon so I hope for the best. I will be spraying 200 at least maybe more.
Old Apr 1, 2007 | 07:16 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Originally Posted by Rhino79
Mahle also make all the Formula 1 pistons I believe.....thats what sold me at first, if they can hold up in those cars, they can damn sure hold up in LS1's! They DO have basically no skirt, they make a little noise but not bad. I'll use them on whatever I build next for sure, they are in my buddies 408 we built, not a problem yet!
Also used by most in the NHRA ....Mahle for sure have a proven history.
Old Apr 1, 2007 | 08:33 PM
bigdsz's Avatar
Just out of curiosity, why didn't you consider Wiseco? They are obviously top shelf.
Old Apr 1, 2007 | 10:39 PM
WS6NIGHTMARE's Avatar
I beleive they ran MAHLE in the CR-R also (24 hr LeMans), I dont know about the C6-R though.
Old Apr 11, 2007 | 10:16 PM
LS1 Swapper's Avatar
Voted against the Diamonds, just put a set in and had all sorts of fun with the reluctor wheel and the #8 piston, big FU to Diamond. Apparently there is a special piston(which wasn't included with my set) for this issue. Thanks...
This was for a 4.00" stroke pistons set, other then that they look like top notch items. weight and measured identically. Mahle didn't make the piston CC I wanted, still wish I would have bought them instead.
Old Apr 17, 2007 | 10:23 AM
PREDATOR-Z's Avatar
Wiseco
Old Apr 17, 2007 | 01:26 PM
  #32
JPH's Avatar
JPH
cp pistons
Old Apr 17, 2007 | 10:39 PM
  #33
01 BERGER CAMARO SS's Avatar
Going with Mahle for my 347 LS carb build. Ive heard nothing but good thoughts about them for years now. If they can help my cuz BBC run low 9's with a crapload of nitrous, then they should be perfect for my set-up.
Old Apr 30, 2007 | 10:31 AM
  #34
chevyguy20's Avatar
just a question but why do so many people compare what the certain brand does other then in a LSX and decide that they are good enough for your curtain build. Just because F1 teams use a certain brand of piston doesn't mean that you are getting the same piston they are useing. I have to believe that they are paying top dollar for the best they have to offer. You are not getting the same thing F1 teams are. Like stated before mahle makes pistons for OE applications and those fail to. Why doesn't anyone see that. I personally would base my decision on proven performance in the application i am currently pursueing. JMHO
Old Apr 30, 2007 | 11:19 AM
  #35
lovescamaros28's Avatar
Mahle pistons are more popular for LS1's.
Old May 27, 2007 | 09:35 PM
  #36
mypoorLS1's Avatar
I went mahle for the cost, coating, and perfect for my application. No nitrous. Thermal barrier, and dry moly coating (anti friction) on the skirts, and they balanced well.
Old May 28, 2007 | 02:59 AM
  #37
BIG BAD BLACKSS's Avatar
Males in the aftermarket LSX world seem to traditionally be a 4032, whereas the diamonds are 2618's. Two totally different meterials for two different applications. 4032 is a weaker material that tends to crack when pushed too far. 2618 is stronger and will tend to deform some rather then crack when they fail. The tradeoff is the 2618s last maybe half as long as a 4032. 2618 isnt for a motor your building to get many years of performance from. Its for a hardcore build thats gonna put down big power on a power adder. In that regard the diamonds far exceed the mahle pistons.
For a moderate n/a build the mahle is your piston. For a big HP nitrous or boost motor 2618 is the only way to go in my opinion.
Old Jan 1, 2008 | 07:36 PM
  #38
racer7088's Avatar
Arrow
Mahles like the powerpak designs are decent cheap pistons but are definitely weaker than the Diamond 2618 pistons on average. The pistons in an F1 engine have nothing in common with these Mahle "powerpack" deals you guys are talking about at all but they are semi decent pistons if you don't plan in using much NOS. The Mahles tend to on average have much thinner ringlands than the other players like Wiseco, Diamond etc.
The only problems we usually seem to see Mahle piston customers having is in the wire locks not fitting due to large burrs on them. If you take those burrs off you will have no problems but I've seen some Mahle destruction from pins coming out where people just tried to force those round wire locks in without deburring them and disaster struck. Again most were the home built variety which have those problems anyway but still we've had to deburr every set of Mahle wire locks we've gotten and I won't sell them to a home builder anymore.
Old Mar 8, 2008 | 09:24 PM
  #39
Gordon0652's Avatar
I didnt vote because its all personal preference and word of mouth.
Both pistons are great! And people use them for many different applications!
Go with the ones you feel most comfortable with!
Old Mar 9, 2008 | 12:52 AM
  #40
Mike94ZLT1's Avatar
wow my thread is old
