can someone explain the specs on a cam to me please.
A/B//C/D//E
ie.
230/234//564/572//114
where
A=Intake duration
B=Exhaust duration
C=Intake lift
D=Exhaust lift
E=Lobe seperation
Hope this helps <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Lift doesn't effect idle quality, but higher lift requires better valvesprings and valvetrain.
Numerically higher LSAs (lobe seperation angle) idle better than lower LSAs, but they shift the powerband up slightly.
So you can expect a 218/218 114 to idle about like stock and make power all over, while a 226/226 112 is going to idle worse, may or may not pass emissions, but make a good deal more power high in the rpm band which is where you'll be when you're racing.
J.
<strong>a4 ls1 with stock programming?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Unfortunately those two do not go hand-in-hand very well. Going with a cam that is not to close to stock makes hard to get it to idle smoothly with stock programming.
