pushrods????
Old Oct 27, 2002 | 03:21 AM
BYBYC5's Avatar
*Bad Trader*
Default pushrods????
should i go with 7.30 or 7.35
i have a tr230 and befor with stock heads i had no coil bind but now with .015 milled i have coil bind, wich ones do you think would be better.... <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Oct 27, 2002 | 03:40 AM
Tin Indian's Avatar
Default Re: pushrods????
Did you happen to read this? It's only about 8 posts down from this post:
https://ls1tech.com/ubb/ultimatebb.p...c;f=1;t=008515
Old Oct 27, 2002 | 05:00 AM
Tin Indian's Avatar
I can't see how you would get coil bind with a TR-230 and .015" off the heads.A combo like that would normally require stock length pushrods.
Just my opinion, but short pushrods are just going to remove any and all lifter preload you already have and put you at zero valve lash.
I got a feeling someone set the spring installed height wrong.
_______________________________________________
<small>[ October 27, 2002, 05:02 AM: Message edited by: Kimchee and Rice ]</small>
Old Oct 27, 2002 | 10:03 AM
BYBYC5's Avatar
*Bad Trader*
how do i check spring installed hieght? they are 941s btw...
Old Oct 27, 2002 | 10:16 AM
BYBYC5's Avatar
*Bad Trader*
BTW i had the cam and springs in there befor the heads were done,and it was fine, but now i got the heads back and i have coil bind...
Old Oct 27, 2002 | 11:57 AM
DaleMX's Avatar
I had a similar experence after a 3 angle valve job and a .008 cut. The valve job set the valves deeper into the heads and I had to shim the rockers up.
