PORTED OIL PUMP, TIMING CHAIN
I was told as far as the chain goes if I do a double roller it will involve grinding the pump and shiming..........I'm not sure
I know Katech and ARE port pumps any differences or any others?
thanx
<strong>what about single roller?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There c5r chain is also $110.ARE is not cheaper.
______________________________________________
E-mail Darren at KB Engine Parts-Australia
kbengineparts@hotmail.com
Rollmaster/Jwis SINGLE Timing Set for less than $70 (total delivered to your door)
Comes with the German made Iwis Ketten single chain and the Australian made Rollmaster adjustable timing gears. This is "plug and play" and needs no shimming of the oil pump like the double chain does. Shimming the pump also means lowering your oil pan. 'Lots O Fun'
Jwis/Rollmaster is much better quality than your stock GM Timing Set.
They also sell the double chain set for a few more bucks. Just my opinion, but I think the double chain is overkill. The single chain got a bad rap because the POS factory single chain (made by Renold in England) has been known to break. And that may lead to catistrophic engine damage! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Ooch!
Please...At least get a new chain. It must come off anyways when you remove the cam. The stock GM chain is prone to breakage and stretching. I would replace it with the Jwis single chain. Much much better quality.
Darren can get you just the chain for a very reasonable price. In fact, just as cheap as the stock chain. About 30 bucks.
BTW, if you are worried about screwing something up, I would think about maybe having a pro do your install, or at least get some help from someone thats "Been there..Done that"
Good luck, <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ron
Sure you can install a Jwis chain on the stock timing gears, but I think most folks would still recommend changing the gears too if givin the choice.
<small>[ October 29, 2002, 04:06 PM: Message edited by: BADZ ]</small>
