coil bind help
Old Oct 28, 2002 | 06:55 PM
BYBYC5's Avatar
*Bad Trader*
Default coil bind help
..well just got it all back together and now after installing the rockers the springs are coil binding at max lift, i checked to see where the pushrod stops turning and then torque to 22# but its only like a half-1 full turn, im hoping 7.35 PRs will help. i had the same cam and combo befor with no bind, all i did was mill .015.. any <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> suggestions?
Old Oct 29, 2002 | 05:32 AM
BYBYC5's Avatar
*Bad Trader*
Default Re: coil bind help
ttt plz
Old Oct 29, 2002 | 11:05 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Changing the push rod length will not help. You will either need to go with dual springs or wider diameter ones to achive the same pressure without them binding.
Old Oct 29, 2002 | 11:58 AM
BYBYC5's Avatar
*Bad Trader*
...why would they NOT bind befor and now suddenly bind if all i did was mill .015 the all i should need is shorter PRs, if not then WHY? i understand i might have to get new springs but i just want to learn why this happened.
Old Oct 29, 2002 | 08:30 PM
BYBYC5's Avatar
*Bad Trader*
TTT
