air fitting tool for cam installs
Old Mar 27, 2007 | 09:16 PM
2fast97Z's Avatar
Default air fitting tool for cam installs
please direct me or tell me what the tool actually is that you use to keep the valves up while doing an ls1 cam install.. need this asap
Old Mar 27, 2007 | 09:17 PM
brad8266's Avatar
A lot of people use the jrp tool, it isnt air operated its just a long dowel type thing.
Old Mar 27, 2007 | 09:19 PM
blkbird's Avatar
Thats for the lifters, you can go to any parts store and they will have a hose with a fitting to hold the valves up to change out the springs, if this is what you are asking for.
Old Mar 27, 2007 | 09:23 PM
brad8266's Avatar
lol, yeah thats right stupid me. I got
yeah its just a hose that threads into the plug hole and has a air fitting for a line on the other end
Old Mar 27, 2007 | 09:26 PM
2fast97Z's Avatar
autozone has that? what would it be called?
Old Mar 27, 2007 | 09:28 PM
blkbird's Avatar
Cant remember the exact name, just ask them at the counter and yes, autozone has them. Thats where I got mine.
Old Mar 27, 2007 | 09:29 PM
blkbird's Avatar
Dont be too hard on yourself, we all make mistakes.....
Old Mar 28, 2007 | 12:37 AM
ArcticZ28's Avatar
Not this guy. Mistakes are unintended things. In order to avoid these, I always intend to be an idiot. This way, when it works as intended, it's a sense of accomplishment. And, when I actually make sense, it's an added bonus.
Old Mar 28, 2007 | 01:05 AM
ArrestMeRed99Z28's Avatar
hahahaha, arctic is my new favorite philosopher
AJ
Old Mar 28, 2007 | 07:23 AM
V6 Bird's Avatar
no he is talking about the valves....Your best and easiest method is TDC. I dont even bother with the air anymore because its suck a PITA to get the damn house connected or screwed in the hole.
Old Mar 28, 2007 | 07:26 AM
brad8266's Avatar
I like that idea.
Old Mar 28, 2007 | 07:27 AM
brad8266's Avatar
Yeah man I know. You didnt read any farther than my first post did you?
Old Mar 28, 2007 | 09:33 AM
King James's Avatar
The hose can be found in compression test kits.
Old Mar 28, 2007 | 09:53 AM
99blancoSS's Avatar
I rent it all the cam swap tools for a very reasonable price. The JPR Rods, The Crane dual spring tool and the air fittings for the cylinder head. And NO its not the hose from a compression tester. Its $40 from Napa for the air fitting's and hose. You can rent all three tools for less from me.
If you can put a spark plug in you can use the hose. If you cant you shouldnt be trying to do the work in the first place.
Old Mar 28, 2007 | 10:39 AM
MightyBobo's Avatar
Yeah, seriously - I had no issues minus a few times where it just didnt quite want to thread in right away. Most of the time I had no problems getting it to thread in.
Old Mar 28, 2007 | 11:58 AM
King James's Avatar
You sure about that?
Like I said, the hose can be found in a compression test kit.....
Old Mar 28, 2007 | 01:11 PM
99blancoSS's Avatar
HAHAHA HOW MUCH WAS THAT TESTER?!? Mine was like $20 from NAPA and the hose isnt removable. So yes your right you can use a hose from a nice compression tester KIT But to say you get the hose from a compression test kit is incorrect. You can buy it as its own entity and dont need to buy a compression test kit to get it. Which is whats implied when you say you get it from a compression tester. So yes I'm sure about that
Old Mar 28, 2007 | 01:52 PM
King James's Avatar
Read my initial post again, and notice it is un-edited.
The OP was asking what he should ask for when if he went to Auto-Zone, or the like, and was looking for this hose. I was trying to help him out if the idiot behind the counter looked at him like he had 2 heads.
Old Mar 28, 2007 | 01:57 PM
99blancoSS's Avatar
Thats a nice kit by the way, how much did that cost?
Old Mar 30, 2007 | 02:40 PM
2fast97Z's Avatar
yeah they dont sell them at autozone so im going to go to napa
