Oil Pressure Sensor reads > 40 but 0 with AutoTap and EFILive
The analog dial in the cluster reads plenty of pressure. But AutoTap and EFILive read 0 for Engine Oil Pressure. If it was truly zero wouldn't I get very high engine temp, or a code, or some other sign? What can I do to make sure I do have good oil pressure?
Re: Oil Pressure Sensor reads > 40 but 0 with AutoTap and EFILive
oil pressure logging doesnt work on the f-body for some reason, at least in autotap. Dont worry about it.
yup, doesn't seem like the PCM monitors oil pressure... or if it does atap and efilive don't know what to look for
Thanks. You guys are right. If you look at the PCM C1 and C2 connectors you see there is no pin for Oil Pressure only Oil level.
