best place for cheap heads and cam install stuff?
looks like i can get gm headbolts from SPDC for $34
what about head gaskets, need a 4" bore, who should i call?
do i need any other gaskets, i know the intake will be fine and the valve covers will be fine but i haven't ever had anything else apart on one of these so i don't know if i need to buy any other gaskets.
how do you know when you need pushrods? and if i need some who has the best price?
thanks
Some say you can reuse the intake manifold gaskets. I talked to a GM tech that said he sees alot of intake leaks when reusing intake gaskets. Plus, under boost, I think the intake gasket would be pretty important.
I dont think you would need longer pushrods unless you went with a high lift cam and a thicker head gasket.
Manley chromoly pushrods can be had for less than $100 from SDPC also.
