LS6 Cylinder Heads
Old Nov 1, 2002 | 02:01 PM
CanuckSS's Avatar
Default LS6 Cylinder Heads
Is there a difference between
2001 and 2002 LS6/Z06 Cylinder heads??
Thanks,
Dave
Old Nov 1, 2002 | 06:09 PM
99 Black Bird T/A's Avatar
Default Re: LS6 Cylinder Heads
It's my understanding the bare heads are the same but the valve set up is different. I think the 2001 and 2002 bare heads are the same. However, the 2002 intake & exhaust valves are much better.
Old Nov 2, 2002 | 12:27 AM
SStrokerAce's Avatar
The 2002 have lighter valves, with the exhaust valves sodium filled to help with heat.
Bret
Old Nov 2, 2002 | 10:30 AM
Ian's Avatar
Ian
So, if you're planning to purchase the heads to have them ported and larger valves installed, you should get the cheapest ones?
Old Nov 2, 2002 | 05:05 PM
CanuckSS's Avatar
The 01 and 02 ls6 heads are priced differently
and have different part #'s.
Ian-That is a good question. I am interested in knowing
the same thing. If you want a stage two head from
say, MTI or Cartek does it matter what head you give
them as a core??
Thanks,
Dave
