Hunting idle??
Old Nov 2, 2002 | 02:22 PM
May Spin's Avatar
Default Hunting idle??
My local dealer has just replaced the rings due to high oil consumption. And now the car is experiencing a minor problem.
Withen 20 seconds from a cold start-up the rpm's surge within a 200-300rpm range.
The dealer said to give the computer time to learn. Well, 300 miles later and it's still at it.
Any idea's before going back to them. I was thinking a vacume??
TIA.
Scott. 00 WS6 M6.
Old Nov 7, 2002 | 12:08 AM
99 Black Bird T/A's Avatar
Default Re: Hunting idle??
Might want to spray a little carb cleaner near the egr, intake, TB & so on and see if the idle changes, this could help spot a vacuum leak.
Good Luck
Old Nov 7, 2002 | 01:25 AM
SStrokerAce's Avatar
you could also do a idle relearn, that should solve that. See if when it does this if you hit the AC it changes.
Bret
