HELP....NEED TORQUE SPECS
Old Nov 4, 2002 | 11:21 AM
Taspeed's Avatar
Default HELP....NEED TORQUE SPECS
for the main caps. I've got: torque em down to 15lbs and then 80 degrees. Is this right? Just doesn't seem like enough. Chiltons has been wrong before.
Old Nov 4, 2002 | 11:58 PM
JAY4SPEED's Avatar
Default Re: HELP....NEED TORQUE SPECS
Hi, this is straight out of the GM 2001 service manual for the F body. Need any more fastener specs or clearances, just email me...
Crankshaft Bearing Cap Bolts - Inner Bolts-First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap Bolts - Inner Bolts-Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap Side Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap Studs - Outer Studs-First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap Studs - Outer Studs-Final Pass in Sequence
53 degrees
Jay <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ November 05, 2002, 12:18 AM: Message edited by: JAY4SPEED ]</small>
Old Nov 5, 2002 | 12:18 AM
jmX's Avatar
jmX
The reference I have for those bolts says the same so its probably correct.
Old Nov 6, 2002 | 09:38 PM
JAY4SPEED's Avatar
Glad I was of some help <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I'm a tech at a chevy dealer so I have full access to factory service manuals. I may not be able to tell you which heads flow the best, but I can sure give factory torque specs!
Jay
Old Nov 7, 2002 | 12:03 AM
Taspeed's Avatar
Thanks.
