head cam and flycutting info
Is there a guide made with head and cam combos that lists what combos of heads, gaskets, cam, bore etc.. that need flycutting or not? I know this is kinda a long shot but i thought i would ask. Reason being is i am going to do heads and cam this summer and we grind custom cams at work so i am make anything i want. I am thinking of Dart 205s, Patriot LS6 and PRC LS6 heads. I'd like to get the heads that would give me good flow and can accept a large cam on a stock bottom end 346 without flycutting.
In summary if you are getting stock ported heads without milling and a cam that is not real big like those listed above you probably won't have to flycut, but just to be safe, I suggest calling TSP or whichever vendor you will but from and ask them.
