Choosing a 422, Iron or Aluminum?
<strong>My thoughts are that the aluminum is going to be better in the areas of heat dissipation (important in a high output motor) and weight (important in a race car) but the iron will probably have better sleves. This is just a guess based on all the horror stories I've heard about re-sleving aluminum blocks. IMHO, the AL block should beat the snot out of the FE block performance-wise due to the heat alone.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So far we have...
-PROs for Aluminum
--Heat Dissapation
--Less weight--Anyone know how much more the Iron 6.0 blocks weigh compared to the aluminum? Isn't the LS1 like 40 pounds lighter than a LT1, I guess that could give us a rough idea.
-Cons for Aluminum
--Potentially a weaker motor due to the fact aluminum is a softer metal? Essentially a "throw away motor" as a friend once referred to an aluminum motor as.
-PROs for Iron
--Stronger than Aluminum
--Can be resleeved safely
--Theoretically should hold up to abuse better
--Cheaper than Aluminum
-Cons for Iron
--Weighs >40lbs more then aluminum
--Heat soak
Man, now that I sit down and think about this myself I kinda answered my own questions lol -- it looks like we will all have to decide which is the best for our cars based upon what we have listed here.
If anyone else has any Pros/Cons that I have not listed post'em up
<small>[ November 07, 2002, 10:14 AM: Message edited by: CamaroSS_2002 ]</small>
Also, the head mechanic at FLP, told me that the ironblock would make more power b/c of the heat retention as a combustion engine will make more power with more internal heat, etc. Just something to think about.
MTI 427 Roadster <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
con- adds 80-100lbs, not 40!
pro- stronger deck, less distortion
pro- will take more detonation for sure
pro- cheaper cost to machine block
I run a 6.0 block bored .060 over stroked to a 422ci.
-PROs for Iron
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Can be resleeved safely??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Iron blocks don't have "sleeves", The block is made entirely of cast iron, not aluminum with cast iron sleeves.
As we speak MTI is building me a LQ4 427 Ironblock stroker bored 4.060". Assuming no spray or other forced induction, but otherwise hard driving, when would you expect my ironblock have to be resleeved b/c of the wear that you mention in your reply to this post.
THanks,
I know it's not a big PRO, but it is a PRO.
From my understanding most aluminum blocks have to be re-sleeved once they are bored out. I could be wrong though.
