SLP springs?
Old Nov 7, 2002 | 06:26 PM
99 Black Bird T/A's Avatar
Default Re: SLP springs?
I know of one case where an SLP spring broke with a MMS 224 cam.
I'd check out the REV-1116 dual springs for unmachined stock heads. Thunder Racing sells them. I think the REV duals will probably hold up better than the SLP's.
Old Nov 8, 2002 | 12:06 AM
eb02z06's Avatar
Default SLP springs?
Are the SLP springs any good? I'm a little worried about spring choice with the comp cams breakage and all. I will only be able to change springs on the car as the heads won't be coming off. I just whant to change them and forget about it.
