help me figure compression ratios
What I would do... don't mill the heads and keep the timing around 26-27 degrees if you can't run higher octane than 93/94. Detonation is going to be your biggest enemy and should be your primary concern. If you don't detonate the engine will do fine (well as fine as the stock rings can be over time with juice).
Tim
<small>[ November 07, 2002, 06:24 PM: Message edited by: TimZ28 ]</small>
