Tea
Old Nov 7, 2002 | 08:48 PM
roguevegals1's Avatar
Default Tea
need to know what are a good set of springs for a 5.3 truck head from tea. going with the tr 224 .561 112 lsa cam. also should i upgrade my rockers. if so what brand and ratio. need real opinions please. do i need to change pushrod length. going to have them millied .015. what setups do yall have. please answer.
Old Nov 7, 2002 | 08:55 PM
dand35th's Avatar
Default Re: Tea
No rocker upgrade, and can't change ratio if you did.. You can run 918's or the duals, either should be fine. Shouldn't need different p-rod length. I have TEA 5.7's and 5.3's. Both run great. One with dual, one with 918's. 224 cam and 7.4 p-rods on both also.
Old Nov 7, 2002 | 09:31 PM
99 Black Bird T/A's Avatar
Default Re: Tea
I like the dual springs TEA uses the Comp 987's.
Rev also makes a dual spring that doesn't require machining the heads that might be worth checking out.
The TEA 5.3 Stage 2 heads ready to bolt on with dual springs will be hard to beat.
The push rod lenght can't be determined just by how much the heads are milled. You also need the cam your planning on using and measure the cam's base circle. Then you can calculate the right length for the push rods.
Old Nov 7, 2002 | 09:51 PM
Tin Indian's Avatar
Default Re: Tea
Just another one of my many pushrod answers <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
That TR-224 cam has been measured to have a [approx] .030" smaller centerline to lobe heal distance than the stock cam. With .015" milled from your heads, you would actually need a .015" longer pushrod than stock to get the exact preload as you had before. Since they only come in .050" increments, your stock length rod would get you closest to ideal preload (only .015" off) No problem whatsoever.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ron,
Old Nov 8, 2002 | 08:07 AM
Default Re: Tea
thanks for the info guys keep it coming.
Old Nov 8, 2002 | 11:18 AM
VTtransam's Avatar
Default Re: Tea
I just got my heads back from TEA, went with the same TR cam as you did, Comp 918 springs, and 7.400" hardened pushrods. A rocker upgrade is not necessary. Good luck
-Matt
Old Nov 8, 2002 | 11:20 AM
VTtransam's Avatar
Default Re: Tea
I forgot to mention that my heads are also the same as yours, 5.3L truck heads milled 10 thousandths.
