Help me ID this noise.. (video inside)
Old Apr 2, 2007 | 02:45 AM
Long Beach's Avatar
Originally Posted by Sweet71
Sometimes the starter solonoid doesnt retract all the way and the gear in the starter hangs up with the flexplate or flywheel and makes a noise like what is heard in the video
How did you fix it, did you end up replacing the starter?
Old Apr 2, 2007 | 07:49 AM
slt200mph's Avatar
Sounds like a lifter has gone bad..
Old Apr 2, 2007 | 10:25 AM
Sweet71's Avatar
I just changed the starter out
Old Apr 2, 2007 | 01:27 PM
mushroom281's Avatar
if it changes with rpm it probably is not the starter
Old Apr 2, 2007 | 04:12 PM
juiSSed1172's Avatar
It varies with RPM.
Old Apr 2, 2007 | 04:14 PM
slt200mph's Avatar
Can you say "collapsed lifter" ...
Old Apr 2, 2007 | 04:26 PM
Thule's Avatar
that is a simular noise mine makes, my one spun a bearing,
Old Apr 2, 2007 | 06:27 PM
autotrix's Avatar
Closed ex-Sponsor Account
^^ It could also be exactly that also, a very easy fix!^^
Pushrods are a weak point in the valve train, yet your chr-mo's might be just beefy enough!
G/L
Old Apr 2, 2007 | 07:14 PM
moeZ28's Avatar
Maybe a pushrod...but kinda sounds like a blown header gasket. Have you checked your header bolts to see if they havent worked loose? I would check them, then take them loose and see that you dont have a blown header gasket. Then start checking the valve train if that doesnt fix it.
Old Apr 4, 2007 | 05:03 PM
I've checked the header gaskets & bolts. I'm running Percy's dead soft aluminums.
Old Apr 4, 2007 | 05:10 PM
autotrix's Avatar
If you cant feel air leaking around the exhaust gaskets then its all good, percys gaskets are pretty good stuff.
You should try and narrow the noise down to a certain cylinder, try killing cylinders until the noise goes away.(or less audible)
Diagnosing a noise is hard and takes some investigative measures. Trying to diagnose from my spot is even harder!! Good Luck!
Old Apr 4, 2007 | 07:10 PM
  #32
tear the car down and take the heads off that is the only way to find your problem
i hope you are not still driving it
Old Apr 25, 2007 | 03:11 PM
  #33
LS100CAMSS's Avatar
My car makes a noise similar to that the engine is cold, but it only does it when rpm's are just beneath 2k and is will only do it for a couple of seconds. It also has lifter tick on cold start-up.
  #34
LS100CAMSS's Avatar
My car makes a noise similar to that when the engine is cold, but it only does it when rpm's are just beneath 2k and is will only do it for a couple of seconds. It also has lifter tick on cold start-up.
Old May 6, 2007 | 09:16 PM
  #35
melchoir's Avatar
My car also has a similar noise, it's about the same volume in the same areas at idle, and does increase with rpms, and becomes nearly inaudible at anything over 2k or so, and is most noticeable around 1200rpms I'd guess.
It's been like this since 11/06 for me, one day I hope to find the answer.
Old May 6, 2007 | 10:51 PM
  #36
My noise turned out to be a bad lifter. It looks like my 918 went bad on this valve, and it allowed the lifter to 'hop' on the lobe. The lifter won't pull out from the top, so I'm going to slide it out the bottom when I swap cams tomorrow. The TR224 cam in it now is pretty chewed up.
