Help me ID this noise.. (video inside)
I have had a weird 'chirp' for a while. It would still be there even if all the belts are off. It would come & go..
I changed my clutch out a few weeks back, and like two days later, this really loud ticking developed. The car wasn't over revved or anything.
Today I:
changed the oil, cut open filter, no metal shavings... ran old oil against magnet, nothing stuck.
took off valve covers, inspected springs & rockers.. nothing broken. I loosened & retorqued all rockers to 22lb/ft
Replaced header gaskets with percy's dead soft aluminum gaskets.
Checked all exhaust flanges, tightened, etc. (FLPs like to leak)
It's still doing it.. Is it the sound of a bad lifter or a spun bearing or something? Oil pressure is fine..
http://www.youtube.com/watch?v=kXKJvoIW0ps
I heard the head bolts are torque to yield or whatever, so I assume those must get replaced?
How much doe OE replacements run? I'm on a tight budget right now.. Any way to test the lifters before I pull the heads?
gm racing lifters $217
arp head studs $239 optional
gm mls head gaskets $43
new cam $400
cam swap gasket kit $68
new upper fast intake gaskets $55
or you can get the tsp basic head and cam gasket kit $149
you choice of cam $3++
ls7 replacment lifters from scoggin dickey $99
i took my valve covers off three time before i decided to pull the heads and it wasn't until then i couldn't see my problem
No more noise! This happened at about 171K on my 98.
Hope this helps
Hope this helps
