jesel roller rockers
Does Jesel make roller rockers for the LS1(stud mount) in the stock 1.7 ratio? I thought I saw some used for sale- can't find them on jesel's site. Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Yes they do. The Jessel J2k series.
my part# is K2A-2004409T
1.7 rockers on shafts. Had to get custom shafts since my valves are longer than stock.
<small>[ November 09, 2002, 02:16 PM: Message edited by: SIR ]</small>
binksz06- out of curiosity, is there a reason that you are wanting to stay with stud-mounted rockers??
The reason that I ask is because the J2K rockers (at least from what I have seen) are considerably more expensive than the sportsman series (Jesel SS). The going rate on the SS Jesels is @$700; I also got mine straight from Jesel.
They are non-adjustable, though, so you'll have to mind your pushrod length (if you're wanting adjustable rockers, you may want to look at the T&D pieces as I believe they are less expensive than the adjustable Jesel's).
Just my $.02...
Just my $.02...
BurnOut -I'm a newbie trying to figure out what I need/want over the winter. Stock '01 LS6-switching to cnc-ported '02 heads(milled.055")and 239/251, .570" ,106 cam. Flycutting pistons. Don't need to adjust on this motor so the JeselSS are a great idea. Thanks every one! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
