Need to change timing belt with cam swap?
With that many miles on your car it would be a very good idea to replace the chain especially since you'll be doing a cam swap it will be easy to swap out the chains.
Good luck with your cam swap <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> and take your time with everything
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by '01WS6/'99SS:
<strong>With that many miles on your car it would be a very good idea to replace the chain especially since you'll be doing a cam swap it will be easy to swap out the chains.
Good luck with your cam swap <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> and take your time with everything</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah while you're in there spend another hour and swap it. I swapped out the set for a double roller setup, only $150 or so.
-Dave
-Dave
