Engine removal ?'s
Old Apr 1, 2007 | 04:50 PM
MS3Z's Avatar
Default Engine removal ?'s
Where is the best place to bolt your chains from your hoist to? I have the engine tore down to the short block. I was thinking the larger bolt holes for the heads.
Old Apr 1, 2007 | 05:09 PM
bigdsz's Avatar
The head bolts are the way to go. Like an idiot when I pulled my heads I threw those bolts away and had to put a bolt in a water pump hole and one in a bell housing hole. It worked fine but the head bolts are the way to go.
Old Apr 1, 2007 | 05:12 PM
CaliboyTA's Avatar
that what i used, worked fine for me
Old Apr 1, 2007 | 07:15 PM
MS3Z's Avatar
Ok thanks
Old Apr 1, 2007 | 07:37 PM
transam69230's Avatar
One in the rear corner on the right, and one in the front corner on the left. That is the way i did it.
Old Apr 2, 2007 | 07:25 AM
slow95z's Avatar
just put a jack under the k member
