Looking for a 382 all bore rotating assemblies.
I believe you need to sleeve the block if you want to stick with the stock length crank and get that displacement.
All bore motor is, 4.125" and 3.625 crankshaft, wiseco makes a shelf piston for this application.
If you are going after building a 382 motor we have Eagle rotating assemblies, match balanced to JE pistons/rings included,bearings etc. $2399 shipped.
Wouldn't you need a wet sleeve as the LS1 block isn't supposed to go over 3.905? Or 3.915 or something like that?
