Double Valve Springs??
Old Nov 12, 2002 | 10:02 PM
Chad00ws6's Avatar
Default Double Valve Springs??
I'm just curious if this is a good idea and how much it will be worth to me. What are the advantages and the disadvantages of using this. The parts for my motor are on order and I was wondering if I should go this route?? Will it give me more power or what. Thanks for the info.
Old Nov 13, 2002 | 01:47 PM
strokedls1's Avatar
Default Re: Double Valve Springs??
It's worth it if you are going to run a high lift cam say (.600+). You will have increased seat pressure, but that center spring is some insurance if you happen to break an outer spring the valve won't drop. Rev and Manley both make a good product.
Old Nov 13, 2002 | 03:40 PM
Chad00ws6's Avatar
Cool I think I am going to go with this option as I think it will help me run a larger lift cam and be streetable. I also think it will be a good deal if I do break one and the other holds.
