Help, #1 is not firing???
Old Nov 13, 2002 | 06:55 PM
TXNC5's Avatar
Default Help, #1 is not firing???
What all should I check?
Plug
Plug Wire - Can I test this? How?
Coil Pack - Can I test this? How?
Injector - ...
If I change the plug and it still doesn't fire, then what should be my next step? What actually drives the firing sequence? Everything else seems fine.
Thanks.
Old Nov 13, 2002 | 07:21 PM
TXNC5's Avatar
Default Re: Help, #1 is not firing???
Thanks. It was a bad plug. They told me they changed them out! You never know.
