RETAINERS AND KEEPERS
Old Nov 13, 2002 | 08:21 PM
ABNRNGR (Aka Dean)'s Avatar
Default RETAINERS AND KEEPERS
which ones to use with isky 295-d's and will stock keepers work?
Old Nov 14, 2002 | 04:52 PM
Default Re: RETAINERS AND KEEPERS
anybody?
Old Nov 14, 2002 | 06:34 PM
JS's Avatar
JS
I wouldnt run a stock retainer with the ISKY spring
I would instead buy the COMPLETE KIT that Isky just cam out with instead.
It consists of:
Locators
Retainers
Keepers
Shims
Springs (WITH A INNER DAMPER)
Dont take the damper out,It fits the new locator setup that ISKY just released.This is a TOOL ROOM spring and IMO probably the BEST single spring u can run on an LS1 setup..
JS
Old Nov 14, 2002 | 06:45 PM
what's the install height with the isky ret? I have a set of ret for 941's and the install height is at 1.72, that's not going to work. The isky site states 1.775 for these springs, but i understand people are using the comp ret with a 1.8 install height? Also i don't have the dampners or locaters for the springs.
<small>[ November 14, 2002, 06:46 PM: Message edited by: Dean ]</small>
Old Nov 14, 2002 | 11:07 PM
JS's Avatar
JS
Call Isky for the new info..
U must run all there parts to make the application work
www.iskycams.com
JS
Old Nov 15, 2002 | 06:04 AM
thanks JS
Old Nov 16, 2002 | 08:29 PM
QuickSilverTA's Avatar
Have you got any info from Isky yet dean? I was going to run the 941 retainers with them to. Let me know if you find out anything about the kit.
Old Nov 16, 2002 | 09:55 PM
I talked to Isky and i bought the 707 st retainers which puts them at an install height of 1.775, which is recommended for these springs.
I'm not sure which ret i have now, I've never seen these before. I bought them from jmx and the install height was too tight. 1.720
<small>[ November 16, 2002, 09:58 PM: Message edited by: Dean ]</small>
Old Nov 16, 2002 | 11:53 PM
jmX's Avatar
jmX
Dean, those are Ti retainers MTI installed on my car about 2 years ago along with comp 941's, back before I bought the car. I removed them a while back since I had larger springs done.
Others had used identical retainers with that 295-D spring before from what I was told.
Old Nov 17, 2002 | 12:41 AM
Jon i sent you a PM, yea i remmber you telling me that they should work. The fitting was good, but hte height came in too tight. I'm sending a pic to Jeff at thunder to ID these things. I went ahead and ordered some steel ones from Isky.
