stock cam ?
Old Nov 15, 2002 | 01:58 PM
Robzilla's Avatar
Default stock cam ?
does anyone know the specs on a stock 2000 cam?
Old Nov 15, 2002 | 10:04 PM
02 SOM WS6's Avatar
Default Re: stock cam ?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Stock cam specs
We put the cam that came out of Jason99TAs motors on the Cam Doctor last weekend and it was 200/210 499/499 117lsa.
Paul
www.thunderracing.com
1-877-516-7223
We measured the specs on an '01-'02 cam that was lying around the shop.
The specs are 197/208 .466/.475 on @ 118.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Nov 16, 2002 | 09:22 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Are you sure those numbers aren't switched around? I thought the 01/02s had a more aggressive cam over the pre-01 cars. Just curious.
James
Old Nov 16, 2002 | 09:51 AM
pekkaz's Avatar
I've seen posted many times 01-02 cam is the milder one. That's one of the methods they used to get away without EGR.
Old Nov 16, 2002 | 10:10 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
It's neat to see actual info on the factory cams, you don't see it very often. I'd say the bottom line is: none of the stockers are worth much! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Those numbers don't seem logical for the 01-02 engine. In order to get rid of EGR you need more I-E overlap; that's the only way to get some exhaust dilution into the intake mixture WITHOUT using an EGR valve.
Milder cams don't let you eliminate the EGR, more aggressive ones do.
I'm not doubting the above numbers, it just doesn't make sense.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Nov 16, 2002 | 10:58 AM
pekkaz's Avatar
Increasing overlap may have EGR like effects but you'd also get unburned fuel to the exhaust not exaclty resulting in clean burn. Decreasing overlap on the other hand prevents fuel from leaking. Which effect dominates in a production engine I dunno.
This would support what you said though :
http://www.ls1info.com/article.php?sid=186
