Please Advise - SDPC Rollmaster Timing Chain/Set
With the engine still in the car, are there any concerns with installing this double roller set up?
Thanks for your help.
I know with the double roller you have to remove the oil pump and put a shim under it (kit comes with shim).
I've also heard that if you plan on using an ASP Crank pulley you'll have to have some machine work done.
Do a search on the site for cam and oil pump installs. Some of the posts have really good links to instructions that while not just the timing chain, show what's involved.
But from what I've seen/read there aren't any issues to be aware of
<strong>Cant help you but was wondering which version of the timing chain everyone was purchasing: the regular or heat-treated torrington bearing one?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I bought the heat treated... it was like 85 bux, for that price you can't beat it...
Chain is nice and tight when installed and i advanced cam 4*, perfect for my combo. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Paul J.
As for which chain, I went with the SPDC heat treated double rolller for $85 like mentioned above. I should have said that in the first post.
Any issues with doing the double roller in the car?
I don't recall seeing a shim in my Rollmaster kit.
