Can the LS2 bolt in to the Fbody?
Old Apr 3, 2007 | 08:47 PM
blackbird345's Avatar
Default Can the LS2 bolt in to the Fbody?
Like the subject says. Also can the LS1 heads bolt on to an LS2 short block?
Old Apr 3, 2007 | 09:38 PM
nmp27's Avatar
Yes with some work/wiring changes
Yea, had some LS6 heads on the 402 for a while, no issues
Old Apr 3, 2007 | 10:13 PM
david vericker's Avatar
The LS2 comes from the factory with 2001 type LS6 heads.
Old Apr 3, 2007 | 11:57 PM
fstls2camaro's Avatar
the ls2 will bolt in perfect all you have to do is move the knock sensors to the side of the motor and get the wire extension for the knock sensors and the cam angle sensor.
Old Apr 4, 2007 | 12:13 AM
Great info, thanks a lot guys!
Any idea how much the LS2 short block can take?
