scat crank-shafts
Old Nov 17, 2002 | 04:32 PM
Solid 346ci's Avatar
Default scat crank-shafts
hi all,
i have been reading this bourd for long time, and getting great information from it.
here is my question bare with me please.
i am thinking building 346ci soild cam engine. the thing is, i know that i have to upgrade my rods and bolts to withstand the high ramp of the cam. but if i wanted to spray NOS let say 75-150hp, i have been told with the amount of stress and pressure, even the nitrited stock crank wont handle it..
by extensive research. i reached to scat crank-shafts.. they are forged and cheap ($800-1200)
anyone has any info on them.. are they good quality and handle the beating
inlight me please
thanks in advance
Ali
Old Nov 17, 2002 | 04:59 PM
Nasty N8's Avatar
Default Re: scat crank-shafts
Very good products but I don`t think there cranks for LS1 is that cheap yet. You should have no problem running your stock crank in that setup.
Old Nov 17, 2002 | 05:32 PM
Fenris Ulf's Avatar
The stock crank can handle it no problem.
Old Nov 17, 2002 | 06:13 PM
so how much the stock crank handle?!??!
cause i thinking getting oliver rods, custem wisco pistons, custom solid cam from FMS like 240/248 .700/.700 112,T&D 1.9rockers, and GTP stage 3 heads with 11.8 cr and 2.055/1.56. and a TNT f1 kit and ofcourese upgrade the fuel system.
so you are saying all that and 150 shot of nitrous will be no problem..
and last but not least, why the heck the LS1 cranshafts are so expansive..
Ali
Old Nov 17, 2002 | 07:17 PM
99RamAirTA's Avatar
What do you really plan on revving it too? The stock crank should be able to handle it no problem. You probably will spin a bearing or two eventually though. I am running a heads cam car with a pretty big cam and a TNT wet kit also and have had no problems. I spin it to about 6600 which i am sure isn't near what you are gonna be doing but I am on a completely stock shortblock.
BTW, Ls1 crankshafts are expensive cause they are new and there isn't that much market for them yet. So most crank companies don't even offer anyting for them yet. Unlike the regular good ol CSB parts aren't a dime a dozen for this moter.
Old Nov 18, 2002 | 12:05 AM
so in order to prevent bearing spin, what kind of bearing should be used..
iknow that the coated bearing are the best is auto racing industry.
please state the best bearing brand and type to prevent such a thing..
Old Nov 18, 2002 | 12:14 AM
Red Shift's Avatar
Harlan on the FI board is throwing 700 hp at a stock crank!!!!!!!!!!!!
