Rod bolts- ARP?
Old Apr 4, 2007 | 09:47 AM
sleek silverado's Avatar
Default Rod bolts- ARP?
Will they fit in my LM7 (5.3)?
Thunder says Yes.
Texas Speed says they require machining?
Katech's are on back order for 2 months.
TIA, and I did do a search.
Old Apr 4, 2007 | 09:54 AM
Oops, meant to put this in the Internal section.
Old Apr 4, 2007 | 10:09 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Throw them on and run. The LM7/LS1/LS6 (and some others I'm sure) all used the same bolts from the factory and use the same part number for the ARP bolts
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Apr 4, 2007 | 12:11 PM
So if they don't fit, you will take them back Do I need to buy thread sealer or any thing else to do the job? Thanks!
Old Apr 5, 2007 | 04:49 PM
N4cer's Avatar
What are you going to seal on the threads? They don't prevent anything from leaking. It's a connecting rod.
Old Apr 5, 2007 | 04:54 PM
Are you talking about moly lube?
And if you bought them from us and you don't want them, yes...I'll take them back
__________________
Old May 21, 2007 | 05:34 PM
BLWN1's Avatar
How much for some to fit a lq4? I need head bolts and gaskets as well....
Old May 21, 2007 | 05:53 PM
Your LQ4 uses the same rod bolts as well. As for head bolts and gaskets, we have them all listed on our website (ARP, GM, Cometic, etc) or feel free to call for more help also!
__________________
Old May 21, 2007 | 11:10 PM
WILWAXU's Avatar
Ask and ye shall recieve
Old May 22, 2007 | 12:10 AM
KCS's Avatar
KCS
Moderator
Thunder says Yes.
As far as machining goes, ARP suggests resizing the rods .002" for the new rod bolts. But when I did this about a year ago on a 375 ci iron block I wanted to put together, I couldn't get bearings for them.
Just giving you heads up.
