5.3 vs LS6 heads
I've ran both the LS6 heads and the 5.3's (current setup). Old numbers with the LS6's are in my sig. Haven't put it on the dyno yet for the new setup, but hope to soon.
Also depends on who you have setup the heads. Valve sizes can vary from stock up to larger (2.04/1.575) for example.
LS6 heads I believe retain stock CR, while 5.3s will net you a small increase in CR (10.75-10.8:1).
Properly setup, either head would serve you well and produce good gains.
in general
5.3 heads are great for "smaller" cams (>228)
Ben T.
